RC beam design (required reinforcement ) -EC2
Refaat
Advisor Advisor
Message 1 of 12
Refaat
Dear Colleagues ;
I am trying to calculate the required longitudinal reinforcement for simply supported beam according to EC2 requirements .
1. Why does Robot calculate the provided reinforcement based on the total reinforcement amount( bottom plus top ) at any section on the beam (Pls take a look to attached capture) . Since the EC2 (Clause 9.2.1.1(3) ) asked to check the maximum amount of reinforcement for tension and compression separately ?
2. May I know that the changing value of (Young modulus of elasticity for concrete " Job preferences" )(e.g from 30000 Mpa to 10000 Mpa) doesn't show any changes in the analysis and design results? . It should effect on stiffness of structural elements , is it ?
Thax
Refaat ,
Replies (11)
Message 2 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
This clause is currently supported in the RC Beam design module but not in the RC Member required reinforcement one.
It does
and design results?
In the RC Design modules E is calculated based on strength of concrete and corresponding design code formula.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 12
Refaat
Dear Artur,
Thank you for your clarifications
Refaat ,
Message 4 of 12
How to change the concrete type. When I try to edit the Material proprieties it is blocked. Thanks
Message 5 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Do you want to change it for a bar or for design of reinforcement only? Could you attach a screen capture showing what is blocked please?
Artur Kosakowski
Message 6 of 12
I am trying to calculate the quasi-permanent deflections for a beam. I have introduced the geometry, the actual reinforcement, loads but cannot change the concrete type. It is blocked to C20 for some reason. Also - are the combinations made automatically using all the provided loads? Please see attached the model and a screen shot. Regards Dan
Message 7 of 12
Message 8 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 9 of 12
Of Course!!! Missed that. Thank you!
Message 10 of 12
Is it possible to specify the exposure class?
Message 11 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 12 of 12
Many thanks
