07:05 AM
Hi there,
- Does Robot design radial reinforcement in the provided reinforcement module? The reason for asking is because I get a pop-up box after reinforcement calculation with the following: "Radial reinforcement - option not available. Generated reinforcement may be incorrect"
- If you have no storeys defined within a model and you look to define the structure class and environmental conditions, how is this possible? I am simply looking at a typical slab design and I have not defined storeys when I run a design calculation, I get a message saying the cover deviation is less than recommended by the code. However my options within the dialogue box are greyed out and not selectable (see screenshot)
Link copied
