Radial rebar X and Y
Lembartassimas
Lembartassimas
How should i read required reinforcement for radial and angular direction? For example if radial reinforcement is a bar from center to outer circle how do i get which size of bar and spacing it is because x and y is not direction of rebar.
Simau
Hi @Lembartassimas
According to parameters in reinfocement type  "circular shell"
M. Agayr
Simau
Please ignore my message
That wasn't your question
M. Agayr
Simau
Try this
M. Agayr
rsousa_
When you choose polar reinforcement, X is the radial direction (as choosen by @Simau in the previous post) and Y is perpendicular. So Y direction is a tangent direction to a circle that passes in each point with the center point given in the definition of the polar referential (perimeter direction).
If the point P1 given in the polar referential is the center of the circles given, you have:
Your reinforcement detail should look like this:
Regards
