"separate structure" error message
skellyRSA2023
skellyRSA2023
I have an error message separate structure in my model. does anyone know of a way to locate this error simply, as I have double clicked on the message in the calculation messages after I run the model, however nothing seems to show up? does anyone know an easy way to locate this?
Simon.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @skellyRSA2023
Check this article.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
skellyRSA2023
Artur,
I changed the meshing to 1m element size and the type 3 error went away when I ran the model again. I had the bottom 3 levels working fine and then when I copied up the repetitive storeys it seems to have sent things worst as I have now got incoherent mesh error in the model which I have tired everything to sort out but cant seem too, slowly losing the will to live with Robot, LOL, I have a attached the model in the transfer link below, is there an easy way of getting this incoherent mesh warning sorted? I have looked through some of the previous posts on incoherent mesh and tried a few solutions but none have worked. could somebody help me please if possible. I would thought I have some inaccuracies in the model however I have tried aligning it as best I could.
Simon.
Download link to model files
https://wetransfer.com/downloads/502709e11efa895c422441b7c4be0c7920190222150607/8c77545dec3618ebb0cf...
skellyRSA2023
Artur,
got this issue sorted, ran a different mesh type also a lot of issues to sort. cheers.
S.
