Question about modeling in Robot Structural Analysis
Mpcconsultora
Mpcconsultora
Hello.
I have a question about modeling in Robot.
I need to know if you can model a column (like the one in the image) that supports two beams but not on the axis of the element. The column is 0.40 meters by 1.50 meters and each beam supports the ends of the column. I need to model that element as a bar and not as a shell. Is it possible in Robot without the need for auxiliary elements?
I hope you can help me.
Thank you.
Rafacascudo
Yes . set the column on the exact position and Use rigid links(Geometry/additional atributes) to connect the beams
Rafael Medeiros
Mpcconsultora
It works! Thanks a lot...
Rafacascudo
Brazilian, Portuguese?
Rafael Medeiros
Mpcconsultora
Argentinian, Spanish...
