Provided reinforcement - DEFLECTION VERIFICATION
BertelliMarco1095
BertelliMarco1095
Dear all,
In order to evaluate the deflection verification there are two methods (elastic and non linear):
I have a simple slab composed by a single panel where there a void near to the edge.
When I do the deflection verification, the two methods give very different solutions! (elastic Max deflection 20 mm, non linear Max deflection 9 mm).
I'll take the worst solution and modify the structure, but:
I would know if someone can explain me this difference;
if somene is confident with this verification
if someone has real experience on the behavior of this verification.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Please check http://forums.autodesk.com/t5/Autodesk-Robot-Structural/elastic-and-nonelastic-slab-deflection-verif...
Artur Kosakowski
BertelliMarco1095
Thanks a lot Arthur,
but, can you explain me where can we found these document that you attached on your answer? It does not look like the robot guide
