I'm doing my graduation project and I have problem with covergance of calculations. I'm doing 3D model of steel hall.
My model was ok and I reviced a resault of calculations, but I noticed that I have a collision in my model - a cross bracing and purlin crossed each other which is very difficult to create so I decided to make a lower column so that the purlin connection with the column is not at the same height as the cross bracing are located. After that I can't get resault od my calculation. I'm asking you to help me with getting answer of the question: the cause of my problem are settings of nonlinear analysis or the reason of my problem is that I don't have any brace in the direction C' so in that the program can't get the covergance? The changes I've written about are in the axis C'. I attach the link so you can download the files with my model,
model 12_08 before the changes: https://www.dropbox.com/s/m8ujtujfloqbnuo/12_08.rtd?dl=0
and 12_09 after the changes:https://www.dropbox.com/s/9ne94ksybuy9yfs/12_09.rtd?dl=0
Please look at this.
Best regards,
Karolika
@Anonymous I edited the topic for better findability and marked my post as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution.
