Problem: unable to import complex model from Revit to Robot
Hello, I am trying to import a Revit's model of a water tank to Robot. What happen is that the link to RSA doesn't work, after the Revit's export the Robot's view remain empty and any element is able to be lineked. I have red that complex models have to be imported in Robot only through file ACIS (SAT), in this case the export works but all elemens structure are red from the Robot as "panles" structure and I am unable to assaign materials, load or anything else.
I am trying for days to deal with it but the export in Robot doesn't work and I have no clue how to solve it. I have attached the Revit's model, please help me, thank you a lot.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
There are no analytical objects in your model. Only analytical objects (analytical floors, analytical columns, analytical beams etc.) are exported from Revit to Robot.
Krzysztof Wasik
