problem to add seismic code
Message 1 of 10
hi sir i am using seismic equivalent force method by using UBC code, and i cant change ar add some codes such as UBC so if you please show me how can handle it to add any code i wish regards egoze Attachment
Replies (9)
Message 2 of 10
Message 3 of 10
Mohammed_Ata
You can add this from here .
Firstly , you should go to job preferences >> design codes >> loads >> seismic loads and choose your code
Message 4 of 10
heloo dear sir
i am looking forwared to do ( sismic equivelent method )by useing some code as UBC or an code i need
so please tell how can i add it
you can see this attachment
thank you
Message 5 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Only the codes shown on your screen capture are implemented for this method.
Rafal Gaweda
Message 6 of 10
so sir what do you advice to do   calcolation by using  UBC
thanke you
Message 7 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Use ordinary seismic calculations
Rafal Gaweda
Message 8 of 10
so sir what do you advice to do   calcolation by using  UBC as an (equivelent method )
Again thank you help
Message 9 of 10
what do you mean by ordinary seismic from where i can do it in robot can you show me please
Message 10 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
See above, message 3
Rafal Gaweda
