problem : no synchronization with the structure
Hello
I have a problem when starting the reinforcement calculations on RSA 2016, a window opens with a message (no synchronization with the structure) for the selected elements, despite the continuous calculation without problem, only I do not know The nature and influence of the problem. "my model is imported since revit structure 2016". this message is in french, it means (no synchronization with the structure)
thank you.
mustafahesenow
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
These errors suggest that you at certain stage exported these columns from the model to the RC Column design module and then you either deleted the corresponding bars from the model and created new ones or deleted the originally defined load cases and replaced them with the new ones. If that is the case you need to delete these columns from the RC Inspector and then import them again from the model.
Artur Kosakowski
