PROBLEM IN DRAWING GENERATING
WHEN I CLICK DRAWING OPTION, THEN IT SHOW THIS BELOW PIC.HOW CAN I SOLVED THIS PROBLEM?DRAWING GENERATING.png
Muhammed.OPERA
Hi @Anonymous
I think you haven't designed an element to show it's drawings.
First, choose the element you wanna design and deal with parameters then run calculations to let the program design the element then you can show the drawing.
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
BUT SAME ANALYSIS & DESIGN IN ANOTHER COMPUTER GENERATING DRAWING.
Muhammed.OPERA
Mr. @Anonymous
I haven't got that yet but,
If you want to get a drawing like that, it should have been designed.
In your project if there's any designed elements in those stories just choose and get the drawing.
If there isn't just go back to your model > select any element > Design menu > Provide RFT for RC Element.
Then design your element and get your drawing.
Facebook |LinkedIn
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
In order to generate an RC Drawing you shouldn't switch the layouts from the top screen list but press the indicated button instead:
The layout is intended to browse thru the already existing drawings.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
