Printing Graphics
Printing Graphics
Message 1 of 8
Printing Graphics
Hi There,
Can someone please help me how to make printed graphics better by doing following;
  1. Remove the background shading.
  2. Remove text box on each label. The boxes are not correctly positioned anyway.
  3. Reduce the text sizes for the load case & other labels.
  4. Print the graphics to full page while printing on landscape.
Please refer to attached screen print and scans in relation to the above query. The ideal print should be similar to what I can see on the screen.
Thank you,
Replies (7)
Message 2 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
There is no background color while printing.
Update your graphics card drivers.
Update your printer drivers.
  1. Remove text box on each label. The boxes are not correctly positioned anyway.
  1. Reduce the text sizes for the load case & other labels.
Page Up , Page Down keys before making screen capture \ printing or while editing screen capture
  1. Print the graphics to full page while printing on landscape.
Rafal Gaweda
Message 3 of 8
Hi Rafal,
Thank you for your quick response. I will definitely try updating the graphis and printer driver and see the results.
Regarding the text size, I tried with page up/page down. The page up and page down changes the text sizes of the diagrams lablels however it did not change the size of the case label at the bottom. Please refer to the attached. I would like to redure the text size of the Case title "Case 1 (DL1)" and "My 500 kNm .....".
Also there is a shaded background printed on the page (cyanish colour). Is there a way to remove it?
Message 4 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 5 of 8
Hi Rafal,
I have updated the graphic card driver for my NVIDIA Quadro 600 but I can't update the printer driver as it is a company network printer and IT team has contror over it. However I have tried printing directly to different PDF printers (pdf factory, pdf24).
  1. With new robot files the text sizes and boxes around the diagram texts are correct as per you advise. Also there is no background shading.
  2. For existing model (the models I had created some times back) my problem as mentioned above are still presists. Please refer to attached file (existing model).
However I am happy that at least my new files will be correct now.
I still have one question, how can I print the graphics to full page on landscape ? Please refer to the attached PDF (New model).
Thank you,
Raju
Message 6 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
  1. For existing model (the models I had created some times back) my problem as mentioned above are still presists. Please refer to attached file (existing model).
Open file in repair mode
http://forums.autodesk.com/t5/robot-structural-analysis/error-message-quot-encountered-an-improper-a...
Rafal Gaweda
Message 7 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 8 of 8
SébastienVILLAME8093
The sizes of the deformations of the structure are modified with the tool "print preview", would you have a solution for this option does not "resize" my deformation? I will join you with my problem.
With the tool "screen capture" its walking ... but this adds manipulations that I would like to avoid.
Do we have a way for the "print preview" option, that the deformed ones are not modified?
thank you very much
A.D
