Portal frame from LP sections (angles)
Jummybear
Jummybear
Hello guys,
I have a portal frame from L-sections. I need to check column profile. If I use L sections (with y and x main axis) I can define internal bracings for aproriate buckling legth in member definition dialog box by ticking "add automatically coordinates of bbracings at points with adjoining elements in the buckling plane". And if I use LP profiles with u-u and v-v main axis I can not define the same bracings automatically anymore. The solution is manually defining of the coordinates? OR i am doing something wrong?
Rafal.Gaweda
Autodesk Support
Autodesk Support
You are correct.
Rafal Gaweda
Artur.Kosakowski
Autodesk Support
Autodesk Support
or
Artur Kosakowski
Jummybear
Unfortunately I cant use this solution because nodes joints from front/back plane dont mach with nodes from side plane.
Thx for quick reply.
