polar coordinate option disabled!
mgaafar
Message 1 of 8
mgaafar
Hi, for some reason the polar coordinate option for the panels are disabled. i am using RSA 2018 and want to know why it is disabled or it is my version of RSA.
@mgaafar Artur Kosakowski marked post as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution.
Replies (7)
Message 2 of 8
Rafacascudo
I think it is greyed since always. But why would you like to use it?
Do you have more than 1 circular slab?
Rafael Medeiros
Message 3 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mgaafar
If you need that for better display of results then for maps and panel results table it is available. The same for setting the reinforcement directions.
Artur Kosakowski
Message 4 of 8
mgaafar
I have only one circular slab but cut into many sectors because I have the reinforcement in the radial/tangential directions so I want the local axis of each sector to be in the radial/tangential direction.
Message 5 of 8
mgaafar
Hi @Artur.KosakowskiI have the reinforcement in the radial/tangential directions for this circular slab, so I want the local axis of each sector to be in the radial/tangential direction so that when reviewing the Mxx & Myy it will be in the directions of the main reinforcement(local axis) of the panel.
isn't that the intend of having polar local axis option?
as per your comment, is there a way to display the moments in the polar sense even though the local axis of the panel in the global Cartesian directions?
Message 6 of 8
Refaat
Hi @ mgaafar
 “Is there a way to display the moments in the polar sense even though the local axis of the panel in the global Cartesian directions?”
As in the picture.
Refaat
Message 7 of 8
mgaafar
oh Thanks a lot @Refaat
Message 8 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mgaafar
I assume that  the suggestion posted by  @Refaat (thank you) was exactly what you needed Smiley Happy. If so would you mind marking the post made by as the solution so that it is easier to be found by others? Thank you
Artur Kosakowski
