Plate and Shell results issue
alfredmx
alfredmx
When you go to "plate and shell results" table, the first column gives you Panel/Node/Case order, and panels are displayed in ascending order. However, nodes within the same panel are not displayed in ascending order (i.e. node 10475 is displayed before node 237). Is there any way to fix this? If you extract results using API, then you get nodes within the same panel displayed in ascending order.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Send us this file.
Rafal Gaweda
alfredmx
Hello Rafal,
I will upload file through a service since size is about 20mb (without results). I'm attaching a screen capture of reported issue.
alfredmx
Rafal.Gaweda
Autodesk Support
Autodesk Support
Great , Thx
Rafal Gaweda
