Partial Linear Support
Hello everyone,
I've started using Robot for FEM recently and I have a couple of questions regarding linear supports:
Is there a way to introduce a linear support to an edge of a slab/floor, but not to the full length of the edge?
Also, is there a way to introduce a similar support but not on an edge of a slab i.e. a support running through the middle of a slab?
Thank you in advance!
Pawel.Pulak
Autodesk Support
Autodesk Support
No, the linear support can be assigned only to the full length of the edge but it is possible to divide edges in smaller parts. It can be done using Division command when "Generate nodes without..." is switched off.
I have shown it on the screen capture below. I have also activated the display of characteristic points of panels (blue crosses) to better see the limits of edges.
Yes, linear support can be also applied to any line or polyline inside the panel. Of course, if FE mesh was frozen in the panel, after defining such line or polyline it is necessary to re-mesh the panel to adapt FE mesh to the new object.
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
Thank you very much for that.
staffan.flodmark
this was an excellent find 🙂
