P-delta results
P-delta results
EY23
Message 1 of 10
P-delta results
EY23
IF I run P-delta analysis to all the loads on my structure, why in the provided reinforcement module these loads are not shown? if that is true how can I intergrate the results of P-Delta analysis in the provided Reinforcement module Smiley Frustrated
Replies (9)
Message 2 of 10
Rafacascudo
Because your combination has also to be a P-delta analysis.
You can not combine P-delta isolated load cases . It will not work
Rafael Medeiros
Message 3 of 10
EY23
Message 4 of 10
EY23
Thank you for your replySmiley Happy
1)I tried all the load With a new manual combination created to be calculated as p-delta but I got the same issue.(no loads shown in the simple cases)
2)but if make the simple cases static linear and the load combination as p-delta, I'll get all the loads in the simple cases tab, but do robot in this case use any result (especially defection) from the p-delta combination.
what I mean, in ACI-318 we can use p-delta analysis and ignore the factors of moment of inertia for each member. Case (2) above can lead of the same results?
what about the new option in robot 2015 the DAM analysis? can i use it for concrete structure? Will it have any effects on base shear when designing the footing (if seismic load is added)
Message 5 of 10
EY23
How can i check if Robot considered the P-delta analysis results in the rc design module?
Message 6 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
The design is based on the values of internal forces calculated for a model. If they are obtained for P-Delta analysis then RC design module uses them too.
Artur Kosakowski
Message 7 of 10
EY23
So If i run the DAM model robot will automatically take the results to RC provided reinforcement module?
Message 8 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
If you run second order analysis (plus reduction of stiffness added manually as attributes of elements of a model) as DAM model is supported in the steel design module only.
Artur Kosakowski
Message 9 of 10
EY23
So as a conclusion...I cannot run p-delta analysis if i want to use rc prov. Reinf. Module ...i can only use second order analysis with reduction of stifness manually ( so that all the forces will show up)
Message 10 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
By second order analysis I meant P-Delta. As I wrote you can set this kind of analysis to combinations created in the model, calculate the model and use the results of these combinations in the RC design modules.
Artur Kosakowski
