P-DELTA EFFECT
P-DELTA EFFECT
Message 1 of 10
P-DELTA EFFECT
HI all
 I using Robot structural but i can find check with  P-DELTA EFFECT P-delta effect. (4.4.2.2 (2)). And I have some question.
Question 1 : Robot can check P-delta effect?
Question 2 : When I check P-delta effct with my hand I can find them?
Ptot :Total gravity load at and above story considered in seismic design situation same pictural in Robot structural i am right?
dc for X,Y direction  : story displacement determined by linear analysis can you show me with pictural in Robot structural?
Thanks.
Replies (9)
Message 2 of 10
Rafacascudo
For Pdelta , click on Analysis types , select the case or cases , click on Parameters and mark Pdelta
Rafael Medeiros
Message 3 of 10
Thank Rafa, But can you tell me more? I don't have the imformation about delta effect. (4.4.2.2 (2)) eurocode EC8 in Robot
Message 4 of 10
Can any body help me ?
Message 5 of 10
I realy need a help, Please
Message 6 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I'm not sure what exactly you need. Assuming that you  want to use the Equivalent lateral Load method and you can't determine if the condition you indicated is fulfilled just create a combination with this load case and set the analysis type as P-Delta for it.
Artur Kosakowski
Message 7 of 10
Hii @Artur.Kosakowski
I will show for you clear, Do you see my pictural below and text Red where is Robot? Can you show me?
thanks.
Message 8 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Please check:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/ec8-p-delta-verification/m-p/4355029
https://forums.autodesk.com/t5/robot-structural-analysis-forum/seismic-analysis/m-p/7505271
Artur Kosakowski
Message 9 of 10
Hi
I'm not sure I can understand you post, Can you tell me how I can finding " dc : story displacement determined by linear analysis based on design response spectrum " in Robot can you help me clear? My English is bad. thanks
Message 10 of 10
mustafahesenow
Hi @Anonymous
I think You are looking for P-delta checking for seismic load not for P-delta analysis.
If  that correct  please explain to me what you want exactly and according which code in order to help you.
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
