Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Open node table by vba macro
5 REPLIES 5
kamil.bednarek6U58T
354 Views, 5 Replies
I have to open 5 tables in hundred of files every day so maybe someone know the way how to open specyfic tables by using the button in excel.
I would be extremely grateful.
Tags (3)
5 REPLIES 5
You can search the Forum and you will get a lot of info regarding this subject.
Try this and see if it helps you
    Dim RobApp As IRobotApplication
    Set RobApp = New RobotApplication
    ' open one model
    Dim MyPath As String
    MyPath = "c:\lixo\RS.rtd"                    'Put your path or loop
    RobApp.Project.Open MyPath
    ' Create Node Table
    Dim rt As IRobotTable
    Set rt = RobApp.Project.ViewMngr.CreateTable(I_TT_NODES, I_TDT_NODE)
    rt.Select I_ST_NODE, "all"
    rt.AddColumn (0) 'X
    rt.AddColumn (1) 'Y
    rt.AddColumn (2) 'Z
    Dim OutPath
    OutPath = "c:\lixo\RS.txt"                   'Put your path or loop
    rt.Printable.SaveToFile OutPath, I_OFF_TEXT
    Set RobApp = Nothing
 Regards
I'm sorry i caused confusion. I would like to open table window in robot program, without clicking right mouse button and pick Node, Bar tables. I would like to click in excel one button and Five different tables will open in my tab.
On the bottom of the screen:
View | Nodes | Reactions | Bars | Loads | Combinations   <--- these are tabs
I don't want this tables in excel.
I want it here:
 Maybe there is some setting file, where we can adjust tables which open automatically when program is opening.
I have a old version of RSA and there is some issue with tables creation by API and View Manager that is responsible for those tabs.
    ' Create Node Table
    ' check wich columns do you need
    rt.AddColumn (0)
    rt.AddColumn (1)
    rt.AddColumn (2)
    rt.Window.State = I_WS_NORMAL
    rt.Visible = True
    rt.UserControl = True
    Set rt = RobApp.Project.ViewMngr.CreateTable(I_TT_BARS, I_TDT_BAR)
    rt.Select I_ST_BAR, "all"
    rt.AddColumn (10)
    rt.AddColumn (11)
    rt.AddColumn (12)
    rt.Visible = True
 After running this code, if you go to window menu and choose cascade you can see the tables are open but don't appear on those tabs.
Maybe someone can give more insights in this problem or even have a solution.
Regards
hi @kamil.bednarek6U58T
try this
Private Sub OpeningSeveralTablesInRobot()
  Dim RobApp As RobotApplication
  For Each Tbl In Array(IRobotTableType.I_TT_NODES, _
                        IRobotTableType.I_TT_BARS, _
                        IRobotTableType.I_TT_COMBINATIONS)
    RobApp.Project.ViewMngr.CreateTable Tbl, I_TDT_DEFAULT
  Next
End Sub
Best Regards
Tags (3)
