One Way Slab Deflection Problem Concrete
Hi all,
I know that there are many topics related to one way spanning slabs however my question relates to the deflection result of the slab.
I am looking to support hollow slabs on beams - I have had trouble and have chosen to use a orthotropic slab of constant thickness.
I have used a 5m x 8m grid for my test with a 2kN/m2 UDL and the moments on the beams are as I expect them to be and fine.
However the deflection results look odd and I think that the results should be rotated by 90 degrees - please find the screenshot attached.
I have also run other tests and found that I am getting deflections in the positive directions whcih is odd!
Could somebody help please?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you attach the file please?
Artur Kosakowski
Robot Model attached.
Rafacascudo
Seems good to me . Longer beams get almost all the load and are less stiff than the shorter beams.
Rafael Medeiros
