Hi
Please find the attached files.
I set number of generated combinations equal to 64000.
I have 32 live load cases. I used simplified combinations and calculated.
In design module, the message displays that the combinations exceeded 32000.
Why this issue occur?
How can I solve it?
I would suggest you to Define relation in Code Combinations
or open file in repair mode
or delete all combinations, set correct natures to simple loadcases, create combinations again
however still returning same message?
please send us model
Maybe Rafal ,Artur , or Pawel can suggest a better solution
How can I solve it?
Either you are using old Robot version ro we need the file.
Hi Rafal
I'm using ARSA 2014
hi rafal
I creat simple rtd file with 32 live load cases
and I followed ahmedeffect suggestions
but still returning same message
You will not get it working neither in Robot nor in RC module.
Reduce number of live loads or adjust Relations to genarte reasonable number of combinations in Model, convert thjem to manual combinations and import to RC dmodule selecting "Manual Combinations"
Hi Rafal
Thank you for your answer.
I used required reinforcement, it was done well.
When using Provided reinforcement, I got this problem.
Please find the attached link:
Hi Rafal
Thanks for your reply.
But in this model \ in model space you used Simplified Combinations, not Full ones.
I indicated in my first post that I used simplified combination.
What should I do?
Sorry I missed that
What should I do?
Open combinations table, display code combinations select all of them, click right hand mouse button on table, convert Components to Manual Combinations, then while importing element to RC provided module select Manual Combinations.
Hi Rafal
Thank you for your reply.
I tried it several times, but I couldn't manage it.
Please a screencast.
Hi Rafal
I tried simplified combination for one column, the result was 26036 combinations.
While using provided reinforcement for the column, the message "Number of combinations exceeds 32000" display.
Why should this happen?
Example:
Of course in your file with full model it will take much longer because you have thousands of combinations to be converted.
