Hi!
In order to study a trestle tower behavior, I need to evaluate it with an appropriate 2nd order analysis.
Some problems appear during the analysis, that let me apprehensive.
1: A instability (type 3) warning is always shown at beginning of calculations. I cannot resolve this instability, even removing all bar releases. So I question if it has some relevant influence on final results;
2: I perform a non-linear P-Delta analysis, and a non-linear analysis. As you can see on the models attached, the results are wrong for P-Delta, as the deformation on combination C110 is less than on static-linear combination C100.
With the simple non-linear analysis model, deformation results seems more trusty. Is the simple non-linear analysis enough?Does it count geometrical non-linearity of the deformation pattern?
3: I ask you to explain the main difference between these analysis that cause such different results. And, in which cases I should evaluate structural behavior with one or another.
