Non-linear Static Analysis - Parameters
From "Non-linear Static Analysis - Parameters" section in the help:
  • For the Initial stress method - Matrix K actualized after each subdivision - Off.
    Matrix K actualized after each iteration - Off.
  • For the Modified Newton - Matrix K actualized after each subdivision - Off.
    Raphson method: Matrix K actualized after each iteration - On.
  • For Full Newton - Matrix K actualized after each subdivision - Off.
1. Off/On settings above are the same for both Modified Newton method and Full Newton method.
2. The default Robot setting is On & Off, which method does it trigger?
3. What happens when both options are set to On & On?
Romanich
Hi Patrick,
this is error in Help.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak, P.Eng.
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Patrick
The help file is also incorrect (as pointed out by Romanich);
see
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Help-file-error/m-p/3368727/highlight/true#M...
Tony
Pawel.Pulak
Autodesk Support
Autodesk Support
Fixed in the online help.
See:
http://help.autodesk.com/view/RSAPRO/2015/ENU/?gui​d=GUID-FB3C86D3-0E30-43A6-82D6-6C50F429FA0D
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
