Non-linear function as UZ support
1234eddie
1234eddie
Hi all,
I got a weird behaviour and i don't understand it.
See picture below.
on the left one there is a support with linear Kz value. (works.) On the right there is the Non-linear function, in my opinion that one should not go through it's maximum settelement, because the load is lower.
Could someone explain me why this gives me "No convergence"?
@okapawal @JacquesGaudin @Krzysztof_Wasik @Artur.Kosakowski
File is attached
Thanks in advance
Gr Edward
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @1234eddie
Screenshot does not give enough information to verify that problem
Share model for verification
Krzysztof Wasik
1234eddie
@Krzysztof_Wasik
sorry forgot the file
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @1234eddie
Add value for force 0 in support function definition
Krzysztof Wasik
1234eddie
@Krzysztof_Wasik
Many thanks. that solved the "No convergence".
I thought i could be smarter(by decreasing the amount of data)
Gr Edward
