Non-Linear Damper Elements
rsousa_
rsousa_
Hi all,
We aim to properly model preloaded spring dampers devices that are to exist at the top of the piers of a long viaduct.
This way, we would like to know if it is possible to run time-history analysis on a model that includes elements that are characterized by behaviour laws (we suppose by using non-linear releases) such as the following:
f (x,v) = f0 + k . x + c . v^a
where
x is relative displacement
v is relative velocity
f0, k, c and a are constant positive values
Regards
rsousa_
Can anyone says "yes, it is possible" or "no, not implemented"?
Thank you for your help.
Regards
Pawel.Pulak
Autodesk Support
Autodesk Support
No, not implemented.
Only  viscous dampers are available, with linear relation for  velocity.
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
