non convergence of non linear problem
Hi
I cannot get convergence of the non linear problem. Can anyone have a look to the model? I would send it via wetransfer due to the big file's size.
Andrea
Artur.Kosakowski
Autodesk Support
Autodesk Support
Will you post the link to the file?
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
I have made a quick test  and it converges for P-Delta. Do you really need the 3rd order analysis for this structure?
Artur Kosakowski
Perhaps I don't. It depends if my first global critical load is more than 10, but I would like at least to know if it can converge or, otherwise, why it doesn't.
Thanks anyway
Andrea
Artur.Kosakowski
Autodesk Support
Autodesk Support
I think this is to run P-Delta (2nd order) rather than linear static (only first check box marked rather than both) for which the analysis converges.
Artur Kosakowski
