Node to surface tie constraint
I am trying to control a surface of a 2D FE mesh via a node using tie constraints, such that the surface is controlled by the force applied to the node.
The node would then generate an equivalent moment onto the surface as it would be applied at a height above the surface and also the force would be distributed to the entire surface.
Thanking you in advance,
Liam
Rafal.Gaweda
Autodesk Support
Autodesk Support
What is the question?
Rafal Gaweda
How do you control a surface via a node, what is the procedure?
Rafal.Gaweda
Autodesk Support
Autodesk Support
If the panel is flat and the user node is created in its plane - just unmesh panel and move node
IF you mean this:
https://forums.autodesk.com/t5/robot-structural-analysis-ideas/panel-elements-connectivity-with-node...
- not available
Rafal Gaweda
No, I would like to create a tie constraint between a node and a surface, such that a force applied to the node would be evenly transferred to the surface area and the height of the node would allow a moment to be created.
Rafal.Gaweda
Autodesk Support
Autodesk Support
So I guess you mean something like this:
http://forums.autodesk.com/t5/robot-structural-analysis/tutorial-or-exaple-for-machine-foundation/m-...
Use rigid links
Rafal Gaweda
Perfect thanks
