I´m having troubles with the node compatibility option.
In the attached auxiliary structure, the beam 14 is connected to the tilted beam with compatible nodes (Nodes 1 & 6).
I would like to model the connection allowing the movement of the node 1 along the tilted bar and the rotations. So, just the Y and Z directions would be restrained.
Checking the displacements, it is not working on. The displacement of both nodes is not the same in the UZ direction.
Dows anyone know how I can model this conditions?
The model can be found in the link:
