No load imported from a model to RC Wall module
kirilascar
kirilascar
 hi,
For the dimensioning of the sails, sizing menu and then reinforcement real element BA then manual combinations then ok. For the definition of the loads I do not see the value of the loads.
Attached screen shots.
@kirilascar Artur Kosakowski edited the topic for better findability
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @kirilascar
Try to replace the single panel with two smaller ones however with such arrangement of beams and columns do you want to design it as a shear wall or just against the gravity (vertical) loads?
Artur Kosakowski
kirilascar
hi, Arthur
I would like to conceive of it as a bracing wall.
thank you
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @kirilascar
As you defied columns and beams which will act as edge reinforcement of a shear wall I'd consider dividing the panel into two smaller ones among the beams and calculate their reinforcement for tension/compression using the RC Slab reinforcement module.
You can learn about the way of deciding which module (the RC Slab or RC Wall) to use watching the recording of the 5th robot webinar available from here.
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @kirilascar
I just wanted to check if you managed to generate reinforcement for your wall and ask if you found my suggestions helpful. Thank you.
Artur Kosakowski
