no load has been defined
Message 1 of 8
Hi, I am trying to calculate the provided reinforcement for some rc walls and 'no load has been defined' is the error message. The loads have been applied to the structure so i'm not sure why this is showing up.
Replies (7)
Message 2 of 8
Muhammed.OPERA
Hi @Anonymous
What is the version of RSA you are using ?
and what code you are using for Rc Structures?
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
Message 3 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
My assumption is that you actually created a wall in 'stand alone' mode of the RC Wall design module rather than imported it from the model. Try to select a panel in the model first and then use: Design > Provided Reinforcement of RC Elements commands.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 4 of 8
I'm using 2018 version and the French code since British does not work
Message 5 of 8
I tried this and it does not solve the problem
Message 6 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI @Anonymous
Could you attach your model and screen captures showing the steps to follow to reproduce this situation?
Artur Kosakowski
Message 7 of 8
Message 8 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
If you open e.g. the reaction table you will see that all results as Not Available. If you calculate the model again and export the wall from the model there is no issue with missing loads.
Artur Kosakowski
