no convergence of nonlinear problem
Can someone help me with this, I'm fairly new to Autodesk Robot and I am trying to check a design given to us by another engineer. I was originally getting "matrix is not positive definite - the critical load may have been exceeded" error and I have fixed this by adding more bracing. Now I am getting "no convergence of nonlinear problem. I have tweaked the tolerance as per https://forums.autodesk.com/t5/robot-structural-analysis-forum/no-convergence-of-nonlinear-problem/t... and still no luck. If I fix all the bases the problem doesn't arise but I would like no moments in the base.
Any help would be appreciated.
Regards
Kerril
Rafacascudo
too many bar releases . Block torsion rotation on all bars and the model will beautifully converge for all load casesSmiley Winkno torsion release.jpg
Other than that ,You can save a lot of analysis time by setting simple  load cases as live loads , wind, temperature ,etc as "auxiliary" as there´s no point in results for them acting alone on a nonlinear analysis. At least , structure self weight load case must be on the combination.
Having a closer look I found enormous node displacements in your model.
There are combinations with all 4 main wind load cases in the same load combination. It doesn´t make sense to me.
But anyway , probably still too many releases combined with pinned supports although no instabilities warnings reported.
Rafael Medeiros
Artur.Kosakowski
Autodesk Support
Autodesk Support
Thank you Rafael for all your help for all of us on this forum. Much appreciated.
Artur Kosakowski
Many Thanks. I noticed something wrong with my load combinations alright. I generated the load combinations using the automation selection/manual/ selecting all and generate. I feel I may have gone about this the wrong way and as you point out there are cases where all four wind loads are included. I have since removed all load combinations, re-labelled the 4 wind load directions and assigned their nature as wind. Now the automatic generation doesn't include any wind loads in any load combination. Shall I just input each loads case manual?
Regards
Kerril
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Try these steps:
Artur Kosakowski
Many Thanks
