Mx using different Panel Calculation Model
HoshangMustafa
Advisor Advisor
Message 1 of 88
HoshangMustafa
I tried two models with different Panel Calculation Model: one with Partial stiffening, and the other Without stiffening. I got two different diagrams for Mx, the former with uniform diagram and the latter with uniform varying diagram. Please find the attached pictures. I wonder why?
Replies (87)
Message 41 of 88
HoshangMustafa
Hi @Krzysztof_Wasik
1- assuming you agree
2- bar 9, on YZ plane (the picture is from post 37)
counterclockwise
3- bar12, on YZ plane (the picture is from post 37)
clockwise
Message 42 of 88
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
Ad1 - agree
Ad2 - do not agree - Mx from bar 9 acts on node 4 in clockwise direction
Ad3 - agree
Krzysztof Wasik
Message 43 of 88
HoshangMustafa
Hi @Krzysztof_Wasik
So, this is why we don't have a common sense
but in the picture, I applied the sign convention stated on 1)
on the bar diagram, the value is -3.97. Applying the sign convention, if I pointed my right thumb in the direction of the local positive (x-axis) and curled my fingers, my fingers will be curled in the same direction as the positive Mx. So this will be counterclockwise on YZ plane.
But I pointed my right thumb in the direction of the local negative (x-axis) and curled my fingers, my fingers will be curled in the same direction as the negative Mx. So this will be clockwise on YZ plane.
On node 4 this will be counterclockwise. Does it make sense?
Message 44 of 88
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
Pointing th thumb in direction of negative local x axis direction is incorrect
Moment from beam 9 acts on node 4 in clockwise direction (summation with sign "-" according to used convention).
Its direction corresponds to direction of applied load MX in example screenshot below. This load causes torsion moment Mx=-3.97 in beam 9,  transferred directly to node 4
Krzysztof Wasik
Message 45 of 88
HoshangMustafa
Hi @Krzysztof_Wasik
So, this sign convention (the picture below) can't be used to find the direction of Mx transferred from bar 9 to node 4?
Message 46 of 88
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
It can be used when your thumb direction corresponds to x axis direction
Krzysztof Wasik
Message 47 of 88
HoshangMustafa
Hi @Krzysztof_Wasik
I don't catch why you treat Mx for beam 9 differently than My for beam 12 regarding sign convention. If you can elaborate more on this, it would be highly appreciated.
Message 48 of 88
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
For beam 6 you look at node 4 in direction "+ " of local x axis (forces are transferred to bar end node) so sign convention from point 1 should be used for Mx.
For beam 12 you look at node 4 in direction "- " of local x axis (forces are transferred to beam start node) so sign convention from point 2 should be used for My.
Krzysztof Wasik
Message 49 of 88
HoshangMustafa
Hi @Krzysztof_Wasik
Do you know I didn't notice that there are two sign conventions for forces on bars: one at start point 1, and the other at end point 2.
Till now I only followed sign convention on start point 1, and if you review this thread from start, you will notice that all my discussions before were based on this sign convention on start point 1.
Thank you for your patience.
Message 50 of 88
HoshangMustafa
Hi @Krzysztof_Wasik
Please find the attached screencast:
From post 12:
MRy=9.49 kNm
Please find the attached link:
Robot Structural Analysis 2019 Help | Maps (panels) | Autodesk
Using this sign convention:
Checking (0.82+0.41+0.16+0.02+0.02+0.16+0.41+0.82)*(7.15-0.89)=17.65kNm
Is it comparable?
Message 51 of 88
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @HoshangMustafa
I guess that you are trying to integrate Myy moment along bottom slab edge to obtain MRy value from ppanel cuts.
You calculations are not correct.
Mry value is obtained by Myy moment integration along bottom slabb edge. So:
- Myy values at slab edge should be used for integration (actually you have used values from finite elements centers - to small values)
- You have used incorrect formula for integration (you should use "sum of Myy*dl" for each finite element, where "dl" is finite element width and "Myy" value is determined fin the center of finite element bottom edge)
Krzysztof Wasik
Message 52 of 88
HoshangMustafa
Hi @Krzysztof_Wasik
Please find the attached picture:
Using Maps> With description> Description positions> Indicated graphically, I get these results
(1.48+1.36+1.24+1.15+1.15+1.24+1.36+1.48)*0.89=9.31
Using Plate and shell results, I get these results
Node  Myy
2         1.54
33       1.44
34       1.33
35       1.20
36       1.15
37       1.20
38       1.33
39       1.44
4         1.54
Using interpolation,  I get these values:
(1.54+1.44)/2=1.49
(1.44+1.33)/2=1.385
(1.33+1.20)/2=1.265
(1.20+1.15)/2=1.175   ...etc
(1.49+1.385+1.265+1.175+1.175+1.175+1.265+1.385+1.49)*0.89=9.46
Is my interpretation correct?
Message 53 of 88
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
Yes your results corresponds with my estimation.
Krzysztof Wasik
Message 54 of 88
HoshangMustafa
Hi @Krzysztof_Wasik
How this could be comparable with the Maps> Myy, Plate and shell results> MYY, or Reduced Results for panels> MRy?
Message 55 of 88
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
Krzysztof Wasik
Message 56 of 88
HoshangMustafa
Hi @Krzysztof_Wasik
I meant Reduced moment X=9.49, here it's X instead of Y.
Message 57 of 88
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
I do not understand the following
"I meant Reduced moment X=9.49, here it's X instead of Y." Could you explain
Results in my pictures
1. Myy - integral in local panel system,
corresponds to
2. MRy in respect to panel cut line
and also corresponds to
3. Mx - in global system of coordinates.
Please refer to Robot help to chech results interpretation
Krzysztof Wasik
Message 58 of 88
HoshangMustafa
Hi @Krzysztof_Wasik
Maps> Myy, Plate and shell results> MYY, and Reduced Results for panels> MRy are all clear (understandable) for me.
Can you elaborate more on point 3 of your last post?
Message 59 of 88
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
Could you explain what is not clear for you?
Krzysztof Wasik
Message 60 of 88
HoshangMustafa
Hi @Krzysztof_Wasik
Reduced moment X=9.49 of your post (circled with yellow) is not clear for me. Why it's changed to Global X? To me local x of panel coincides with Global X.
