Moving load on truss
basheer.algohi
basheer.algohi
I am trying to understand how does moving load works on the truss.
I tried to create a truss and apply a moving load but the moving load was not available as an option.
I created a frame (similar to a truss) and released all members as can be seen in picture No. 1.
I defined the moving load path on the bottom chord and perform the analysis but the result is not as it should be.
I move the loaded path down the truss and another weird result happens.
Can anyone help with this issue?
As far as I understand, when the load moves on the bottom chord the bending moment should be only on the bottom cored not any other members.
Thank you
Replies (7)
Rafacascudo
Zip and attach the model
Rafael Medeiros
Simau
Hi @basheer.algohi
Delete releases on top and botton chords, and try with a single nodal load, and look if the bending moment shape is correct;
M. Agayr
basheer.algohi
Zip file is attached
basheer.algohi
How did you do that?
I did as you said but the result still not correct:
Simau
Your moving loads are applied to the whole structure instead of lower chord.
When you define the route don't select "automatic"
Model attached
M. Agayr
basheer.algohi
Thanks a lot.
That was very helpful.
basheer.algohi
Thanks a lot.
