Move / Copy Pop Up Window Not Displaying
jreyesN2P7P
Observer Observer
jreyesN2P7P
Observer
Observer
Hello
When I use the edit-> move/copy tool, the corresponding pop up (the one that asks you whether you want to move or copy the object; how many copies to make; etc) no longer appears on my screen. I've tried shutting down and restarting my computer, but once again when I've opened Robot, this problem persists. Any ideas on how I can fix this and see that pop up window again?
JohanDuPlessis
Hi @jreyesN2P7P,
Try Open layouts from template. It has worked for me in the past when panels go missing.
I'm not sure if this will solve the issue, but it's worth a shot.
Rafacascudo
If you are using Windows extended desktop on 2 monitors , check if the copy/move window popped up on the 2nd monitor
Rafael Medeiros
jreyesN2P7P
Observer
Observer
Thank you @JohanDuPlessis  and @Rafacascudo . I first tried tweaking my monitor extended desktop settings, and at first this helped show the pop up, but later after opening and closing RSA it disappeared again. I then tried Johan's suggestion, and this immediately solved the problem! 🙂
