Moment at Pinned Connection
Message 1 of 8
I am seeing significant moment at a pinned connection. Any idea what is causing this?
Please see the screen captured attached.
Thanks!
Replies (7)
Message 2 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Have you ignored reported instability or has the nonlinear analysis diverged?
Artur Kosakowski
Message 3 of 8
mustafahesenow
Can you send us the model please.
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Message 4 of 8
File attached.
Message 5 of 8
The instability is in a meshed slab at a lower level. Please see screen shot attached.
I have circled in red where I am getting the moment at the pin.
Message 6 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Artur Kosakowski
Message 7 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I just wanted to check if my suggestion has solved your issue. Thank you.
Artur Kosakowski
Message 8 of 8
Hello Artur! I have encountered the same problem. The is a moment at a pinned end of a beam. See image below. Moment at pinned Supports.PNG
Do you happen to know what is causing this?
