I wondering what would be a good approach to modelling a modular structure that will apply point loads onto a beam frame? Here's a sketch to illustrate what I'd like to do:
(Above) - That is a typical module that will apply point loads at column locations onto the beams (W27x114) below. Some are single HSS 4x4x1/4 columns and some are double HSS 4x4x1/4 columns that are connected by a single connection. Here's are 2 examples of such connections:
(Above) - The green plates in the 2 images above will be in contact with the W27x114 beams hence transferring point loads to them.
How would I model the two corner HSS columns from 2 modules that are next to each other applying point loads onto the shared W-beam below (as shown in the image below)? Is Robot able to understand two columns applying point loads onto a beam at the same location only side by side? I tried a simple example but I ended up having errors when analyzing it.
已解决! 转到解答。
