Modelling a wide cap beam in Robot
Message 1 of 11
Hey guys
I have difficulties modelling a wide cap beam with the dimensions of 4m*12m (in the plan) and varying thickness from 0.6m (on the edges) to 1.5m (in the middle part). 4 girders sit on the cap beam from each side. The cap beam is supported by a 4m*4m concrete box column. due to large dimensions it has to be subdivided to few elements or possibly a shell element to represent its actual behavior.
I attached a hand sketch of the cap beam. please give me an idea what to do ?
Replies (10)
Message 2 of 11
Rafacascudo
columm - bar with rigid links on top
slabs - shell with variable thickness
Something like this
You can enter the missing slab( or top of columm) part as a load on columm top node
model attached Robot 2018
Rafael Medeiros
Message 3 of 11
Thanks Rafael
But in fact the top surface of slap should be perfectly flat and horizontal. Also is it possible to define non-prismatic shells in 3D frame mode since this option is only available in shell mode, and when I switch to shell mode to define something and switch back to 3D frame I get errors during the analysis.
Regards
Message 4 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
As I already started my picture Smiley Happy Just to illustrate the way it was done by @Rafacascudo (thank you) and in case you want to model have the middle part of the cap as well Smiley Wink
Artur Kosakowski
Message 5 of 11
Rafacascudo
the slab top surface not being horizontal is just a detail . You can be sure the the correct slab stiffness will be perfctly represented even though its geometry is not according to real life.
You can only define slabs/walls (as structural members) in a shell structure type model !!
You cannot go back to frame 3d type expecting the shell objects will appear there like magic Smiley Wink
Rafael Medeiros
Message 6 of 11
Thank you Artur. It was very helpful.
Message 7 of 11
Rafacascudo
Life is hard ...Smiley LOLSmiley LOLSmiley LOL
Rafael Medeiros
Message 8 of 11
life really sucks, I don't know why the hell I chose engineering and why the structural engineering MSc 10 years after my BSc...?!?!
I should blame dad lol
Message 9 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Rafacascudo
With all the help you provide it is actually pretty easy Smiley Happy
I really do appreciate it.  Thank you.
Artur Kosakowski
Message 10 of 11
I was just wondering if there is anyway to make the section independent from points coordinate or create it using relative dimensions ?
I tried your way and it perfectly worked in Plate mode, but once I copy it to another 3D frame file the shape gets distorted. and If I define the slabs in a 3D frame file, the top surface is drawn with a slope by default.
Maybe there is way to draw it in plate mode and merge the segments and make a solid object ?!?!?
Message 11 of 11
Rafacascudo
"Shell"structure type = "3d frame" structure + shell objects (slabs, walls).
You will NEVER get a perfect geometry for this model. Slab face can be horizontal if you model an inclined panel as Artur suggested in his sketch. But your thicknesses (65cm,150cm) will not be vertical.
If you really need a 100% perfect geometry model , use Solid structure type.
But then your life will really become hard 🙂
Rafael Medeiros
