Model RC wall as Cantilever wall
Could you tell how to model RC wall as Cantilever wall ? (attachment)
Refaat
Hi
Here you are
Refaat
Example 20th floor building
so we draw RC Wall from 0F to 20th floor as one element?
what different between draw as cantilever wall and draw cutting by floor? (attachment)
thank
Artur.Kosakowski
Autodesk Support
Autodesk Support
From the 5th RSA webinar:
"Like in case of RC Columns RC Walls should be defined as panels between two neighboring levels of slabs rather than as a single vertical panels through the entire height of a building. This not only allows you to access reduced results for panels or results for stories but it also prevents issues with incoherent meshes at the intersections of walls and slabs which we discussed in our previous webinars about meshing."
Artur Kosakowski
I think it will different result as attacment
Artur.Kosakowski
Autodesk Support
Autodesk Support
Why for the same meshing do you expect the results to be different?
Artur Kosakowski
OK! thank you
