Modal calculation
Modal calculation
Simau
Mentor Mentor
Modal calculation
Simau
I have to study 2 kind of modal calculation in the same structure.
I created modal rive and modal milieu, which are 2 positions of the same crane. To continue with sismic calculation, how can I assign a modal data to a sismic data?
When i follow with sismic calculation, i get only one output, as in the picture
Best regards
M. Agayr
Pawel.Pulak
Autodesk Support
Autodesk Support
It will be necessary to renumber one of modal load cases - to define some seismic cases after the first modal and then other seismic  cases  after the second modal load case. Seismic/spectral, harmonic or time history analysis are taking settings from preceding modal load case.
Renumbering can be done here:
After renumbering please remember about checking/updating load to mass conversion for modal load cases.
If this post answer your question please click "Accept as Solution".
It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
Simau
Many thanks for help
Best Regards
M. Agayr
