modal and masses
modal and masses
Hi, I have some trouble with the following model.
http://www.mediafire.com/view/emb064kx5mn9uh6/Tesis-Robot-06.rtd
  1. I need too many modes to get the mass participation. The model is for 4 storys but it's regular and typical I think it should need 12 max.
  2. The mass fot each story is diferente en Stories 2 and 3 bot the distribution and loads are the same.
  3. The program takes too much time to analyze the model.
I define the spectral case with local code, and only for  "x" and "y" diretions.
Please, I'm sure that is a trouble with the dynamic analysis but I can't find it.
Replies (7)
Rafal.Gaweda
Autodesk Support
Autodesk Support
Time of calculations (from the caclulation note for 9 modes ; multithreaded solver) : 8sec
Time of calculations (from the caclulation note for 30 modes ; multithreaded solver) : 20sec
You need 9 modes in X direction and 30 modes in Y direction to obtain 90+% of masses in each direction
Rafal Gaweda
well, in my case take more time, but my cuestion is for the quantity of modes required for "y" direction, It should be no more than 12 modes and If the trouble is no in the modal options I think is in the mass because the model has diferent mass per story in stories that are the same for example stories 2y3. How calculates robot the mass per story? or what coud be the reason of this trouble? thanks
Rafal.Gaweda
Autodesk Support
Autodesk Support
I would start with checking loads:
Sum of reactions for case 1 for only story 4 = 2012 kN
Sum of reactions for case 1 for only story 3 = 1995,67 kN
Sum of reactions for sw only for only story 4 = 1541 kN
Sum of reactions for sw only for only story 3 = 1530 kN
Rafal Gaweda
I can't find the error in the model,but maybe it's in geometryor loads aply
Rafal.Gaweda
Autodesk Support
Autodesk Support
Check beams - without beams the sw is the same on stories 3 and 4
Rafal Gaweda
story 4 is different to story 3, but story 3 and 2 are the same. Story 1 is different in high. I think ithe sotories 2 and 3 would be checked.. The loads for case 1 applied on beams of story 4 are different.
I found two aspects that may can solve the trouble. I want to know if I'm correct.
  • I was comparing Robot with ETABS and the modal mass participation are different, other aspects of the seismic analysis are similar, like story forces. The method of calculation of Robot is different than etabs, I think this affect the results of mass participation.
  • The calculate of SW for each story is different too, but the total SW are the same. I think there are differences in the consideration of forces of the joints of vertical elements to each story
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
