It took me more time than I expected - too many errors (some geometrical errors not corrected by you as I had asked before).Finally I corrected model.
1. Geometry not corrected - some columns 127 128 157 158 194 195 etc not connected to panels \ beams -> use Detailed Correct \ To plane to correct
2. ALL bars in project are released - I guess due to Revit settings. In attached file I removed releases from columns
3. Linear releases can not be defined on free panel edges
4. Linear releases can not be defined on both sides on common edge if there is no bar \ wall on the comon edge defined.
5. Do not use kinematic links, corect meshes either by program (local mesh generation) or manually moving nodes.
6. Walls (as far as I remember 27 274 not accurately connected with slabs)
7. Due to inaccuracies Model Generation tolerance should be set as 2mm
Cirrected File here: https://www.filemail.com/dl.aspx?id=JWSPKEZZRVVTAAA
Rafal Gaweda
