Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Modal analysis
3 REPLIES 3
359 Views, 3 Replies
Modal analysis
Olá,
Estou com esse erro sempre que tento executar análise modal para uma viga biapoiada. "O número de gruas de liberdade dinâmicos é igual a 0".
Alguém sabe como resolver?
Um abraço!
3 REPLIES 3
Romanich
I suppose that you have to define additional nodes. In the current scheme, all your nodes are fixed, so there are no dynamic degrees of freedom.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Artur.Kosakowski
Hi @Anonymous
I'd say you should follow the suggestion posted by @Romanich for the accuracy of the results but for the model as you defined it you have to use the consistent mass matrix to have any dynamic degree of freedom as otherwise they are in nodes which cannot move being supports.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
in reply to: Artur.Kosakowski
Thank you @Artur.Kosakowski and @Romanich.
I just had to create additional nodes without bar division.
Problem solved!
