Modal analysis problem
Message 1 of 11
I'm doing modal analysis of concrete bedplate supported on steel spring isolators. Stiffness of the isolators is same in x and y direction. My question is: How is it possible that the natural frequency of the structure is smaller in y direction than x?
Replies (10)
Message 2 of 11
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you please share your model for verification.
Krzysztof Wasik
Message 3 of 11
Hi
For some reason I cant share the file. Here is some info:
b=7m, h=2,5m l=9,5m
spring stiffness: kx=ky=9500kN/m kz=12100kN/m
damping:              cx=cy=160kN*s/m kz=240kN*s/m
Message 4 of 11
okapawal
@Anonymous what do you mean exactly by "the natural frequency of the structure is smaller in y direction than x"?
Do you mean mass participation in X, Y direction or displacement shape in a mode?
Waldemar Okapa
Sr Product Owner
Message 5 of 11
Rigid link master node is elevated 3m from the top of concrete bedplate and nodal force at master node is 1500kN
Message 6 of 11
Here is my modal analysis results
Message 7 of 11
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
It seems that it is caused by mass eccentricity.
Normal mode2 ( in X direction) has probably symmetrical rotational component around Y (mass in z =0). While mode 1 has non zero mass in z which suggest non symmetrical rotation around X.
Look at normal modes shapes you should see the difference
Krzysztof Wasik
Message 8 of 11
Hi
When I move the rigid connections to the centre of the structure I have following results
Message 9 of 11
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you check normal frequencies for UZ fixed in supports?
Krzysztof Wasik
Message 10 of 11
fixed the model a bit. Also made support fixed in UZ direction
results:
Message 11 of 11
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
Now frequencies are similar. In my opinion effect is caused by different stiffness for rotational vibrations coming from different diameters in Y and X directions when elastic supports are defined in UZ.
Krzysztof Wasik
