I am currently running a modal analysis in Robot to determine the mode shapes for a steel floor framing structure (see attached screen capture). When running the analysis I received a error message that there are "Excessive releases at the bar". When I hoover over this message all of the beams are highlighted. I want all connections to be "pin-pin" connections (not transfer any moment). To model this, I placed pin supports where the beams will be connected to a concrete wall and released the moment in all directions for each beam (see attached screen capture). I am also receiving several instability warnings for each member regarding the rotation. Is there a better way to model the pin-pin connection so that I won't receive these errors and warnings? The results of the modal analysis seem quite a bit off so I'm not sure whether this is something that I can ignore or not. This is my first modal analysis in Robot so I really appreciate the advice.
Thank you in advance,
Lauren
