Missed rohtml.dll
Missed rohtml.dll
Missed rohtml.dll
Hi Arthur and Rafal
During the calculations of steel connections I become the messages those are in the attached files
Is something wrong with my system?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Had you uninstalled any older versions of before this happened Robot?
It seems that this dll is no longer registered in the system. Try to run Command Prompt as Administrator (press RMB and select this option) and register the file using this syntax
regsvr32 "c:\Program Files\Common Files\Autodesk Shared\Structural\COM\rohtml.dll"
Artur Kosakowski
It seems to be a installations problem
I have had to reinstall all, at this time it runs ok
Thank you
