Miscellaneous concerns in ARSA
HoshangMustafa
Advisor Advisor
Message 1 of 18
HoshangMustafa
Hi all
Please find the attached file.
I calculated Vu & phiVc for column 31 manually (using ACI code)
d=167.5mm
density of concrete= 23.6kN/m^3
column dimension: 400x400
service DL=2kN/m^2
service LL=3.5kN/m^2
b1=400+167.5=567.5mm
23.6(0.2)=4.7kN/m^2
1.2(4.7+2)+1.6(3.5)=13.64kN/m^2
13.64[(7.1)^2-(0.5675)^2]=683.2kN
Bo=4(567.5)=2270mm
phiVc=0.75(0.33)sqrt(24)(2270)(167.5)(10^-3)=461.12kN
Using ARSA:
From Forces table:
Fx=652.81kN
From Slabs- punching for panel 17:
Qadm=467.67kN (manually 461.12kN)
Q=268.17kN
467.67+268.17=735.84kN (manually 683.2kN)
It seems as there's a discrepancy in Q value, if I'm understanding it correctly.
Replies (17)
Message 2 of 18
HoshangMustafa
Hi @Krzysztof_Wasik
Any help would be highly appreciated.
Message 3 of 18
HoshangMustafa
Hi all,
I hope one can help with this.
Message 4 of 18
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
I understand that you expect different Q value (punching force). I see that from Robot you obtain 268.17 kN
but I do not see in your manual calculations manually calculated Q (or I do not understand which value it is)
Coul you explain?
Krzysztof Wasik
Message 5 of 18
napooil
Message 6 of 18
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @napooil
As far as I understand your picture (screenshot is not sharp enough to se all details) you are comparing total vertical load applied to slab with punching force transferred by middle column. Please correct me if I have missed your point.
Please keep in mind that slab is also supported with four columns in the corners, which also transfer vertical load from the slab. It should be considered when punching force for middle column is calculated.
Krzysztof Wasik
Message 7 of 18
napooil
You correct. I forgot to think support with four column. thank you.
Message 8 of 18
HoshangMustafa
Hi @Krzysztof_Wasik
Maximum punching force:
637.4-372.57=264.83kN
Message 9 of 18
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
I understand that you expect explanation why maximum punching force 264.83 kN does not correspond to 268.17 kN
Krzysztof Wasik
Message 10 of 18
HoshangMustafa
Hi @Krzysztof_Wasik
maximum punching force 264.83kN corresponds to direct punching force (punching force without unbalanced moment).
268.17kN corresponds to punching force with unbalanced moment.
Message 11 of 18
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
Is there anything else which shoud be explained?
Krzysztof Wasik
Message 12 of 18
HoshangMustafa
Hi @Krzysztof_Wasik
Maximum shear force= 264.83kN
Please find these attachments:
gamma_v=1- {1/ [1+(2/3) *(b1/b2) ^ (0.5)]}
gamma_v=1-{1/ [1+(2/3) *(567.5/567.5) ^ (0.5)]}=0.4
0.4*(0.46+0.35)=0.324kN
264.83kN+0.324kN=265.154 (in ARSA Q=268.17kN)
How Q is calculated from the maximum shear force= 264.83kN and the attached bending moment diagrams?
I need this for edge or corner columns, but took an interior column for instance.
Message 13 of 18
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
Equivalent Q force including punching force and moments in column is calcualted iusing the following formula.
Q = t*A for biggest t value obtained from the following formula
refer to Robot Help
Formula components are displayed in Slab calculation note
Krzysztof Wasik
Message 14 of 18
HoshangMustafa
Hi @Krzysztof_Wasik
Thanks. I tried it this way:
Message 15 of 18
HoshangMustafa
Hi @Krzysztof_Wasik
I tried calculating deflection for element 36 described in:
Robot Structural Analysis 2019 Help | Plate and Shell Deflections - Calculations | Autodesk
Please find the attached picture:
Am I correct? Because I want to proceed calculating deflection.
Message 16 of 18
HoshangMustafa
Hi @Krzysztof_Wasik
Message 17 of 18
HoshangMustafa
Ix=Iy=b*h^3/12=910*(200)^3/12=606,666,666.67mm^4
E=23249.13MPa
D=EI=14104.472kN*m^2
Message 18 of 18
HoshangMustafa
Hi @Krzysztof_Wasik
I'm sorry for being late.
D/B=(14104.472kN*m^2)/2.98=4733.044
Is it ok?
