Meshing issue with openings in wall panels
skellyRSA2023
Message 1 of 8
skellyRSA2023
I was wondering if anyone can help me. I have built a model in which the external perimeter walls are made up of concrete RC walls based on a constant thickness with reduced stiffness. However, to form openings in all these panels I have used the panel opening tool and done in each of the panels. this is nothing different from what I have done previously. However the opening is in the panel and can be seen and highlighted in RSA. However, when I view the mesh in the panel the complete opening is meshed over for some reason? (see attached 6 snapshots). The model has run Ok and you can view results etc, and there are no error messages in the model stating this. However, I am slightly worried now that my results may be incorrect? due to this. Has anyone ever come across this before? if so how was it fixed and did it cause an error in results/load takedown. Anyone's help on this would be appreciated.
Many thanks,
Simon.
Replies (7)
Message 2 of 8
Rafacascudo
can you zip and attach the model?
Rafael Medeiros
Message 3 of 8
skellyRSA2023
Rafael,
Thanks for looking at this, see download link to file below. its a large model file, as I have also included results file. the strange thing is on the internal wall panels with openings it is doing the same thing as in meshing over openings as initial I thought maybe I the opening off the square from the plane of the panel, but the panel opening is formed in the panel. I have looked at previous models which I had saved as I was doing this model i.e. saved model at intervals and the model which was created previously does not have this issue so it seems to have only happened when the last time I ran the model.
Download link
https://we.tl/t-pBXCQwKK1A
Simon.
Message 4 of 8
skellyRSA2023
Hi @Rafacascudo , @Artur.Kosakowski
Apologies, but was wondering did anyone get a look at this issue, its really vexing me, i have looked the previous forum answers but can not seem to find a solution.
Simon.
Message 5 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @skellyRSA2023
Try to run detailed correction indicating three corners of the building's wall plane (two outer bottom corners of the side panels at each side and one outer at the top) and  then run local meshing for these panels.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 6 of 8
skellyRSA2023
Artur,
Thanks for your help on this. I have done as you said for just one panel, and it worked when i then froze all mesh and rerun the calculation model. I have reviewed the new foundation loads and they seem to be slightly less than when the model had the meshing over the openings so it should be ok design wise, it could be that none of the openings were accounted when the openings were meshed over and thus the dead load was higher.
Is there any reason why this happened in the first place? As i add each opening on each individual panel to try and ensure its on the same plane as the wall plane. However sometimes when a buildings walls are skewed on plan it can be diffcult to get the panel face on elevation, is there a easy way to do this? Same goes for panel cuts, if a panel is at a skew when making a panel cut, should the panel cut direction be in the x or y direction as it usually in the xy direction.
Simon.
Message 7 of 8
skellyRSA2023
Just to clarify in case anyone else comes across the issue.
1. I used the detail correct tool as noted above on one panel only.
2. Then i meshed out all the wall panels with openings again.
3. Freeze all mesh
4. Rerun the calulation model.
5. There were some further incoherent mesh areas to be sorted which i sorted by looking at them indiviually and freezing mesh.
6. Then model worked ok when calaulations run.
Simon.
Message 8 of 8
auraconcept
Community Visitor
Community Visitor
That solution works, however - is there any tip to run detailed correction sucessfully for all the panles in the model at once?
