mesh problem
mesh problem
mesh problem
Hi guys,
I have a problem with the mesh of my structure. I set up the meshing option as for the suggestion found here in the forum and I can't understand what's wrong with the model. Please find below a picture of the mesh: some panels show a clean squared mesh, other have those big triangles. Can someone help me with this? Why do I have different mesh if the panel are identical with the same mesh settings?
Luisa
Artur.Kosakowski
Autodesk Support
Autodesk Support
Select the panels you want to re-mesh and switch off Kang algorithm for them. Make sure that you unfrozen the meshes or deleted them or run local meshing rather than model generation.
Artur Kosakowski
Rafacascudo
Luisa ( brazilian?) , without having the model I would recommend you to check if all the bars end nodes  and also the panel charateristic points are defined in the exact same Z coordinate.
check it with all the decimals !
Rafael Medeiros
