Mesh problem circular shaped panels
1234eddie
1234eddie
Hi all,
I have a model in RSA 2022 where i have modelled a hollow tube as panels. i now have the problem that some of the panels won't mesh (nr 2) or mesh incorrect (nr 1). See pictures, this is quite annoying as i need to deliver the calculation results to my client.
Can someone explain me why this happens and how it can be solved for this and future projects?
Mesh of number 1
File is attached.
@Krzysztof_Wasik @Artur.Kosakowski
@autodesk, some of my other topics are still pending:
Slow printing since using sharepoint
Non-linear function (NLF) in printout
Thanks in advance
Gr Edward
  • Mesh
EduardoMeruvia
@1234eddie
Just opened up your model in Robot 2023, and meshing seems to be fine there. I deleted the mesh and re-mesh several times and results were the same, no issues from my side.
Did have to mesh the pipe only first though to get a "clean" square mesh. See pics below.
EduardoMeruvia_0-1668208118616.pngEduardoMeruvia_1-1668208169197.pngEduardoMeruvia_2-1668208196336.pngEduardoMeruvia_3-1668208224806.png
