Mesh issues
Mesh issues
Message 1 of 15
Mesh issues
please help me out, its urgent.
I have finished modelling and am having mesh issues with clouding. do I suppose to assign thickness to the clouding? see attachment
@Anonymous Artur Kosakowski marked  post as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution.
Replies (14)
Message 2 of 15
Rafacascudo
if they are being meshed , then they are not claddings
Rafael Medeiros
Message 3 of 15
yes is not meshed
Message 4 of 15
the file is attached please, someone should look at it and tell me what is wrong
Message 5 of 15
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi chris,
I'm not sure what help you need - is it to solve meshing issues? It seems like you missed the file.
Artur Kosakowski
Message 6 of 15
Artur.Kosakowski
Autodesk Support
Autodesk Support
As I can't see the file:
1. Faces - most likely you have no load applied to some cladding
2. Incoherent meshes - Try to run detailed model correction to structural axes
3. Kinematic constrains
Make sure you have marked iterative adjustment of meshing. You may then decide on use or lack of generation of kinematic constrains
Artur Kosakowski
Message 7 of 15
thank you artur. but please the problem still haven't be solved. I still have one warning "Faces (the object without assigned thickness) not used in solid area generation. FE mesh has not been generated". what should I do to overcome this? please the file is attached, you can look at it as well for solution.
thanks.
Message 8 of 15
Artur.Kosakowski
Autodesk Support
Autodesk Support
You missed the file but had you checked that you applied loads to each of the defined claddings?
Artur Kosakowski
Message 9 of 15
the file is attached now please.
I have not assign any load to any member of the structure, apart from the self weight of the structural menbers.
thanks.
Message 10 of 15
Artur.Kosakowski
Autodesk Support
Autodesk Support
When as I wrote
1. Faces - most likely you have no load applied to some claddings
you define loads on the claddings this warning will no longer be displayed. In other words if you don't need to apply such loads just ignore it.
Artur Kosakowski
Message 11 of 15
ok let me give it a trial that way. thaks
Message 12 of 15
Rafacascudo
Your model clearly has meshing precision problems like ,
You should watch the good webinars 1 and 2 about meshing best practices and troubleshooting. On Build your Robot Structural Analysis IQ - YouTube
Use the regular modeler instead of solid one .Unmark it On Tolls/job preferences/ work parameters
Rafael Medeiros
Message 13 of 15
thank you so much. please this is the problem am having now. "Linear load has not been applied to a panel". what do I supposed to do and how do I do it. the file is attached as well.
Message 14 of 15
please am still waiting for your response.
thanks
Message 15 of 15
Artur.Kosakowski
Autodesk Support
Autodesk Support
@Anonymous Hi Chris, As you created another topic for load application I'd like to ask you if we may consider your meshing problem as solved and if so would you mind to accept Rafael's post as the solution so that others could find it faster?
Artur Kosakowski
